AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Shape Connection vs. mapimport problem
1 REPLY 1
DP5150
283 Views, 1 Reply
I'm having problems with shape files in C3D/Map3D, when I "connect" to the shape files they are in the right location but when I "mapimport" them they are considerly off in a different location within my drawing.
I've check the drawing coordinate settings with my shape's *.prj files and they match and are using the same coordinate system.
Any idea or way to correct this would be appreciated, I can probably drag everything "mapimported" over to a common point but this indicates something is wrong and out of whack somehow.
1 REPLY 1
antoniovinci
in reply to: DP5150
Erase the .PRJ files and try again: if it doesn't work, zip and attach all here, sir.
”Boost
