AutoCAD Map 3D General
Active Member
Message 1 of 5 (349 Views)
Setting Up Coordinate System / Geo-Referencing Help!!
349 Views, 4 Replies
08-14-2012 06:27 AM
I have an Map that was drawn in regular autoCAD drawn 1:1.  I know the coordinate system that I need to assign to it and some known coordiante but how to I go about getting my current map to be correctly geo-refenced.  I am relatively new to AutoCAD map.  Is there a way to tell AutoCAD map that a certain few points are at certain coordinates, and the rest falls into place?  Thanks in advance for any help.
antoniovinci
Message 2 of 5 (338 Views)
Re: Setting Up Coordinate System / Geo-Referencing Help!!
08-14-2012 10:55 AM in reply to: bbrou25
No way: the assigned CRS (command _ADESETCRDSYS) will affect the whole map.
If you have survey points in a local coordinate reference system, you could _ALIGN them snapping to known nodes belonging to the main CRS.
Other ideas, gentlemen..?
Distinguished Contributor
Robert_Fritz
Message 3 of 5 (319 Views)
08-14-2012 10:46 PM in reply to: bbrou25
I'm not sure if I do understand what you want to do but there is a Map command called _adersheet which migth be helpful in your case. Just check the Map manual for further details,
Rob
http://raumpatrouille3d.blogspot.ch/
Message 4 of 5 (308 Views)
08-15-2012 05:48 AM in reply to: Robert_Fritz
What I've done in the past is insert overhead images that are georeferenced, then move my CAD file over the image but that's still eyeballing it, not exactly georeferenced.
Another way is if you have shape files that correspond to your CAD file in a way that you can match them up.
Active Member
Message 5 of 5 (304 Views)
08-15-2012 06:15 AM in reply to: snakerancher
I actually was able to obtain an shape file that corresponds to my CAD file.  My thought were they same, connect to the shape file, move my CAD drawing "on-top" of the shape file, and then my CAD file would be geo-referenced.
This is the problem, I am having issues with drawing units.  The original CAD file was drawing in architectural units (smallest units being an inch). The shape file looks like it wasn't necessarily drawn in units, or I guess since it is using the coordinate system LA83-SF-MOD, its units would be US Survey Foot.
There in lies my problem, when I connect and bring in the shape file it is 1/12 the size of my corresponding CAD drawing.  The Shape files 1 unit = 1 foot, whereas the CAD drawings 1 unit = 1inch.
I can scale down the CAD drawing by 1/12 and it will match up but I this CAD map is also an XREF to 10 other maps, I would have to open then and scale them down, line them up, etc.
Any ideas to avoid this. Thanks.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
