Did you ever find a solution to this? - I'm having the same problem.. I want to script an ArcGIS (SDE) layer import into AutoCAD. Having to manually enter connection data using dialogs, and it's a pain!. Had a search aroundfor 'Workflow Designner' and '.oxml' but found nothing.
Pete
Is this working on 2013 version?
In the designer windows as in the xoml file the connection details are stored, but as soon as the workflow is run the "Connect to data store" input screen is shown and the user needs to fill in all the details.
Also the prompt for parameters at runtime is unchecked.
Is this supposed to rememeber the connection details from the configuration/designer?
Would expect so.
tx
Luc
