AutoCAD Map 3D General
Active Contributor
Message 1 of 2 (774 Views)
Scale Bar in 2013
774 Views, 1 Replies
08-09-2012 08:59 AM
I've tried using the new scale bar in Map 2013.  But when I try to insert it inton my map, the size of the scale bar makes it huge, it's way bigger than the layout.  How do I decrease the size of the scale bar?
Michael Kohler
machadt
Message 2 of 2 (737 Views)
Re: Scale Bar in 2013
08-14-2012 05:18 PM in reply to: mekohler
Hi Michael,
The scale bar should always shows the correct scale ratio of the map in a viewport. When the viewport scale was changed, the map scale was changed accordingly, in that case we have to adjust the scale bar. Here we have two choices, one is to adjust the scale bar size and keep the division value unchanged, another is to change the division value and keep size unchanged. This is configurable in “Scale bar properties…” dialog, the “Adjust divisions on zoom” checkbox.
For example, we have a map scale 1:10000 and viewport scale is also 1:10000 (viewport scale can be different from map scale), we want a scale bar shows 1:100Meters, then division value is 100.
If viewport scale was changed to 1:20000, then scale bar size is doubled in order to keep division value (100) unchanged.
If we check “Adjust divisions on zoom”, then scale bar size won’t be changed, the division value will become 50. Because the same division size presents ½ original map distance now.
Hope this will help!
Tatiana Machado
AEC-ENI Application Engineer
You are not logged in.
Ask the Community
