AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
SID image file not available on Map2008 installed on Vista? has anyone..
1 REPLY 1
sf5d
282 Views, 1 Reply
else experienced this problem? What is the solution.
I'm reinstalling CADMap on a Vista machine and opening a drawing we had previously had SID images loaded on, now they will not work. there isn't even a SID selection in raster images.
Shaun
1 REPLY 1
ClaraAlmeida
in reply to: sf5d
Hi Shaun,
Reading your thread, I´m not quite sure if you had SID imagens Inserted ou Connected to (via FDO).
But, apart from this, I think you should try installing Raster Design Object Enabler for Map 2008 (in your case).
If you don´t know about this, Object Enabler is free, and can be downloaded from Autodesk´s website. It will load the "extra" image file types that are now missing - including MrSID.
Cheers
Clara
”Boost
