To import a polygon shp and maintain the islands relation with the outer border, all you have to do is to, in the import shp dialog box, NOT to select the Import polygons as closed polylines (leave it unchecked).
Map will import the info as Mpolygons. If you select data, the dbf data will be stored as Object data.
