You have a couple of options:
1) You can use a utility called "xyz2dxf" that will create a dxf file based
on the point data, or
2) Preferably you can import this point file into LDD and create a terrain.
This is done through terrain model explorer. Create a new surface, and
under "TIN Data", Right-click on "Point Files" and then "Add Point File".
If you still have an .xyz extension on your point file you may want to
rename it to .txt through windows explorer. This should set you up with a
LDD Terrain based on the DEM point data.
Hope this helps,
-MJB
"smh" wrote in message
news:E08853B4E8F4347325B37FE422BE1A71@in.WebX.maYIadrTaRb...
> I am running LDDT2 with PIII 650 and 380 Meg Ram, Win98SE.
> I am trying to use some DEM data from Geocomm, and trying to un-tar,
> decompress etc, and so far have been able to un-tar and get ddf files. Now
I
> have tried to use the data translators and found that the data format has
> been changed a little and the translators based on the Sol Katz converters
> do not work anymore.
> The USGS indicated I should use MicroDEM to create an ASCII.XYZ file.
> Okay, once that is done, can anybody give me an idea on what I need to do
to
> get the ASCII file into AutoCAD or AutoCAD Map?
> Any and all help is appreciated.
> SMH
