The IsMajor is a Boolean type and I don't see any easy way to convert it to
string to use the "like" or an inter for =. But if you use the Elevation
property you can use this expression.
Abs ( Sign ( Remainder ( Elevation, 50 ) ) ) where the 50 in this is
the major contour elevation, replace it with what yours is set at. False
will be 1, True will be 0.
Note: I only tested it on one contour file.
Murph
http://map3d.wordpress.com/
"A_Bell" wrote in message news:6295185@discussion.autodesk.com...
How do a create a calculation for an SDF contour file that changes the false
or true to 0 and 1? I have been trying and I can't seem to get the correct
combination. Also I don't get the full set of actions on the top of the
dialog box. Functions like: =, LIKE, and others don't show up. I know
this is something simple, but I'm not getting it.
Any help is appreciated.
