Convert the existing Block Attribute data to Object data and then try using the below script to extract data from Object Data.
(strcat (strcat (strcat (strcat (strcat "TagNumber" :Tag_Number@Test) "\nManufacturer" :Manufacturer@Test) "\nEquipment_Description" :Equipment_Description@Test) "\nItem_Type" :Item_Type@Test) "\nRoom" :Room@Test)
where Tagnumber is the name to show as tooltip before the original retrieved Tag_Number from the object data table name test with field name Tag_Number.
Hope this solves your problem.
GoodLuck,
Krnkishore.
