Matt,
Unfortunately the Tiling Scheme is missing a Rotation option.
This could then be equated to a DVIEW TWIST in the layout viewport.
Good wish list item.
On the other hand if you must get this done, here's a possible workaround.
Warning: It is not pretty.
Once the map has been completed you can use the command
MAPEXPORTCURRENTMAPTODWG. Geospatial Workspace - File>Export>Current Map to
AutoCAD DWG (Exports styled map to a drawing file)
Open the file created and remove the coordinate system, enter a period ".".
Create a new file, attach the exported dwg.
In the Define/Modify Drawing Set select the Drawing Settings button. Right Click
the Drawings heading in the Map Explorer tab.
Select the attached drawing at the top of the dialog box and toggle ON Simple
Transformation.
Change the Rotation to 17.3.
Click Apply, Close and the OK buttons to exit.
You can then Add Drawing Data> Query Source Drawing - Location - ALL in Display
Manager
And finally....create your Map Book.
Mark Martinez
The DC CADD Company
