AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Rename Multiple Layout Tabs
2 REPLIES 2
4785 Views, 2 Replies
I am currently workin on a large drawing that has many tabs (145),  I have made a mistate midway and would like to find a way I can rename them quicker than "Right Clicking" on each tab to change it. That will be very time consuming.  Does anyone have any solution to this.
Also, is there a way to print a list of all of the current layouts within a drawing/
Thanks in advance for any help.
Richard
2 REPLIES 2
Have you heard of a lisp routine called "Tabsort"? If you google it, I'm sure you could find it. I think it will work great for what you are looking for.
TerryDotson
If you were to consider third party software, ToolPac's Layout Manager will let you quickly rename multiple layouts using a find/replace, a single click builds a printable report of the drawings layouts, and a lot more !!!
”Boost
