AutoCAD Map 3D General
Active Contributor
Message 1 of 14 (403 Views)
Raster Image Transparency
403 Views, 13 Replies
10-31-2008 12:10 PM
How can I make a raster image transparent? I would like to see image #2 below image #1 by making image #1 semi-tranparent. I can make one specific color in the image transparent but to me that is as worthless as... you know what. Right now I am working from a scanned image in jpeg format. I would think it should be easy because any Microsoft Office program can do it. I have searched through multiple Autodesk discussion boards to no avail. Thanks, Doug
*Murph
Message 2 of 14 (403 Views)
Re: Raster Image Transparency
10-31-2008 01:18 PM in reply to: douglawson3952
For color images you can't you can only adjust the
brightness and contrast.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
How
Doug
Distinguished Contributor
Message 3 of 14 (403 Views)
11-05-2008 08:29 AM in reply to: douglawson3952
Contrary to what Murph replied, I do this all the time with our color images.
Connect to the image through FDO
Then export it as a .layer file
Open the .layer file in notepad and edit as follows
Add the Opacity line where shown, adjusting the value to suit your preferences. I use 0.6 for most applications.
Then save and load the layer file
<FeatureName>rasters:Name</FeatureName>
<Opacity>0.6</Opacity>
<Geometry>Image</Geometry>
This works well with 2009's MAPPLOTTRANSPARENCY command to create transparent image plots too.
*Murph
Message 4 of 14 (403 Views)
11-05-2008 09:33 AM in reply to: douglawson3952
OK OK, I forgot that trick.
:smileyhappy:
Contrary
Add the Opacity
most applications.
Message 5 of 14 (403 Views)
11-05-2008 09:55 AM in reply to: douglawson3952
"Trick" is the key word.
It shouldn't be this hard.
And its obviously not documented anywhere.
Active Contributor
Message 6 of 14 (403 Views)
11-11-2008 05:48 AM in reply to: douglawson3952
I agree, it shouldn't be that hard to do, but I was able to accomplish my main goal which was to make the image transparent. Now for a really dumb question... How can I move, rotate, and scale the image I just made transparent? I am not accustomed to working with a Map 3D layer yet.
Message 7 of 14 (403 Views)
11-12-2008 07:20 AM in reply to: douglawson3952
FDO doesn't treat the images as Autocad entities like Map -Image -Insert does, so its pretty much just a backdrop.
You'll need something else to manipulate the image. I have Raster Design, so I create the image where I want it before bringing it in through FDO for the transparency.
Active Member
Message 8 of 14 (403 Views)
11-13-2008 05:24 AM in reply to: douglawson3952
Are you guys having problems printing them out once you make them transparent? I had no luck with making FDO polygons transparent but i can at least get the drawing to print if i set the image to transparent....although it is taking about an hour and 20 minutes to render each plot. The drawing size is around 3M with 2 16M sid images. The images plot in 2 seconds without the transparency trick.
Marty
Active Contributor
Message 9 of 14 (403 Views)
11-13-2008 05:56 AM in reply to: douglawson3952
I have not tryed to plot mine yet. I am still trying to get the image in the right place before I make it transparent. One of the reasons I wanted it semi-transparent was to help align and scale it with other objects in my drawing such as road centerlines and other maps. I will let you know how mine plots when I get to that point. The image transparency definately needs to be put on the autodesk wish list instead of having to do all these work-arounds/tricks. Don't you agree? -Doug
Active Member
Message 10 of 14 (403 Views)
11-13-2008 06:40 AM in reply to: douglawson3952
I agree whole heartedly. I just want to the features as advertised to work....you promote this stuff and then you try and show it off and it just doesn't work. They need to open up the beta groups to more of us IMHO and get this stuff straightened out before it goes public. I think that its transparency in general that's the problem.
Marty
You are not logged in.
Ask the Community
