AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Quick selected blocks don't display, but their properties do...
1 REPLY 1
297 Views, 1 Reply
I am trying to get back some of my work that was "lost" when a crash accured. I had 16 blocks (all the same) inserted into my map at the correct locations. I recovered the drawing but noticed that the blocks weren't displaying. I conducted a quick select for the layer which they're on; it stated 16 items were selected (but they are not displaying). While they are still "selected" I checked the properties & it stated all the correct information (quantity, block name, color, layer, scale, etc...). I made sure all layers associated with the block were not frozen. So it's acting as though they're still in the drawing, but aren't displaying... I searched the discussion groups & was unable to find the same issue. Any recommendations?
Robyn
1 REPLY 1
I may have discovered why the blocks aren't displaying... If I remember correctly, I inserted the blocks before adding their layer to the display manager. I inserted a few more of the same block after adding their layer to the display manager; & they're all dislaying now (minus the 16 prior). Their must be a certain workflow that I'm unfamiliar with, as I'm just using a free trial. Does this sound correct? I must add layers to the display manager before inserting/drawing items on them...
”Boost
