AutoCAD Map 3D Forum
Welcome to Autodeskā€™s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Project Artoo for AutoCAD Map 3D Available on Autodesk Labs
15 REPLIES 15
Message 1 of 16
scott.sheppard
2977 Views, 15 Replies
Project Artoo for AutoCADĀ® Map 3D 2013 software is a free* technology preview that helps you perform geometry cleanup operations on geospatial data stores to improve the quality and accuracy of your geospatial data.
http://labs.autodesk.com/utilities/artoo/
Please trry it and reply to this thread. There is also a thraed in the Civil 3D forum for AutoCAD Civil 3D users who also use AutoCAD Map 3D.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
15 REPLIES 15
Message 2 of 16
Great idea - I have several clients moving data bak and forth in Map 3D in order to do drawing cleanup. This will help a great deal.
On the Zero Length Objects. I have an attached SHP file with multiple vertices at one location. Standard DWG cleanup will fix this on an AutoCAD Pline - but this does not seem to be the case here. I'm attaching a sample SHP file for you to test.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Message 3 of 16
endest
in reply to: scott.sheppard
After installed the Artoo x64, I cann't find the "new Geospatial Cleanup icon" on Tools tab.
Is there other method to open it?
Message 4 of 16
gluckett
in reply to: endest
At the command line type:
MAPGISCLEAN
Message 5 of 16
iam_doss
Hi, where can I get the available clean operation list for every kind of data source and layer? It seems there are some operations valid for line layers but no for polygon layers. Exists that list?
Message 6 of 16
iam_doss
in reply to: iam_doss
Hi, somebody here?
Message 7 of 16
scott.sheppard
Thnak you for your patience. I have alerted the team that this message has not yet been answered. Our Product Manager associated with the technology preview will be back in the office on June 21.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 8 of 16
iam_doss
Thank you for your answer. I will wait for.
Message 9 of 16
As you've found out, not all cleanup operations will work on all data sources.  In fact, some cleanup operations will only work on certain geometry types. Below is a list of available cleanup operations by geometry type:
For Lines:
  • Delete Duplicates
  • Break Crossing Objects
  • Extend Undershoots
  • Apparent Intersection
  • Snap Clustered Nodes
  • Zero Length Objects
  • Erase Dangling Objects
  • Erase Short Objects
  • Dissolve Pseudo Nodes
  • Simplify Objects
  • Weed Polylines
For Polygons:
  • Sliver Polygon Removal
  • Reform Polygons
For Points:
  • Correct Duplicate Points
Mark Christian
Industry Marketing Manager
Engineering, Natural Resources & Infrastructure
Autodesk, Inc.
Message 10 of 16
iam_doss
in reply to: mark.christian
Thank you
Message 11 of 16
scott.sheppard
I have updated the technology preview so it is available in 13 languages - not just English.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 12 of 16
scott.sheppard
The technology preview will stop working on February 1. I will retire it from Autodesk Labs, Thanks to all who participated.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 13 of 16
Dear mr. sheppard,
Is there a command to Clean Up a Feature Objects in AutoCAD MAP 3D 2013 (i.e. Geospatial Clean Up)?
If not, is there any other possibility to Clean Up a Feature Objects (Break crossing)?
Thanks in advance!
Best regards,
Tahir Mavric
Message 14 of 16
gluckett
You could use standard clean up tools if the FDO round tripping was seamless. (i.e. Dynamically dumped FDO attributes to object data for editing).
Imagine this business case:
You have a dwg with new roads and rivers to add to your SDF.
You clean up the layers traditionally.
You push ask that data directly to the sdf since the layer and object data is already mapped.
You refresh your Sdf and the data is
there.
If you miss something, it checks out back into dwg objects with object data, and you can re-clean with clean up tools.
Why re-invent the wheel, when all we need a fixed FDO dwg integration?
Message 15 of 16
tahir.mavric
in reply to: gluckett
Dear gluckett,
Thank you for yout answer.
You example does not reflect my problem properly.
We work with industry model data (feature objects) and I would like to check a Area Topology. When Topology reports an error (that the lines intersect), than I would like to break it on intersection.
I tried to break features lines with drawing Clean Up and BREAK commamd, but didn't make any effect.
Is it possible to use COGO tools, to break feature lines?
Has anyone had a problem with this issue before?
Thanks in advance.
Tahir
Message 16 of 16
tulio.paz
Hello, okay?
I wonder if the project Artoo was incorporated in version AutoCAD MAP 3D 2014.
ā€Boost
