Marion
thanks for your answer, now i have something to tell to my customer, you know, he is
not happy for the re-format operation.
Regards and thank one more time!!!!!!
"Marion Pietsch (Autodesk)" wrote:
> Paolo,
> you're right, Win2K doesn't allow to assign another drive letter for the system
> partition once the operating system is installed and running.
> Hence, I'd recommend to re-format the machine with the default partition settings
> and then re-install Map. The question how to uninstall would be obsolete then
> And I'm sure that will prevent you also from having similar problems with other
> applications.
> Marion Pietsch
> WW Support & Services
> Autodesk GIS Product Support
> yuppies' services wrote:
> > Mark thanks for the tip.....but i can't uninstall.............i have tried to
> > install but alwais stop before end!!
> > and the problem is i can't change the letter af the primary partition of that
> > pc with W2K disk administration don't permit it!!
> > Mark Christian wrote:
> > > Paolo,
> > > I would suggest performing a complete uninstall of map 2000i
> > > http://support.autodesk.com/getdoc.asp?id=TS45252 and then reinstall to the
> > > default drive (c).
> > > Regards,
> > > Mark Christian
> > > GIS Product Support
> > > Autodesk, Inc.
> > > "yuppies' services"
wrote in message
> > > news:3B8D1609.EC677826@yuppies.it...
> > > > I have a problem with installation of MAP 2000i.
> > > > I try to install on a computer with W2K with service pack 2, all appear
> > > > normal and standard, but one thing is not standard:
> > > > the system volume is mapped like F: and not with C:, i don't know how
> > > > and why the customer make this.
> > > > The problem is :
> > > > when the setup program have finished to collect information for
> > > > installation it stop with a generic error message
> > > > Unrecoverable error
> > > > Stopped due to an error
> > > > Is the F: letter of partition? or maybe some conflict with other
> > > > application?
> > > > Is the first time that append to me!
> > > > Paolo Francia
> > > > Y.U.PPIES' SERVICES S.r.l.
> > > > Via Stradivari, 6
> > > > 41100 Modena
> > > > tel.: 059282727
> > > > fax.: 059282737
> > > > p.francia@yuppies.it
> > > > http://www.yuppies.it
> > Paolo Francia
> > Via Stradivari, 6
> > 41100 Modena
> > tel.: 059282727
> > fax.: 059282737
> > > Paolo,
> > > default drive (c).
> > > Regards,
> > > Mark Christian
> > > GIS Product Support
> > > Autodesk, Inc.
> > > "yuppies' services" wrote in message
> > > > The problem is :
> > > > Unrecoverable error
> > > > application?
> > > > Paolo Francia
> > > > Via Stradivari, 6
> > > > 41100 Modena
> > > > tel.: 059282727
> > > > fax.: 059282737
Paolo Francia
Via Stradivari, 6
41100 Modena
tel.: 059282727
fax.: 059282737
