AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Problem with AIMS 2012 64 bit on Windows 2008(64bit) server
3 REPLIES 3
TATA_JUNE2007
592 Views, 3 Replies
Problem with Autodesk Infrastructure Map Server 2012.
I have installed AIMS 2012 64 bit on Windows 2008 server 64 bit. After Installation, I found that it has installed only Map Server & Extension only. But studio has not been installed which contain all the FDO as well.
Anyone help what is the way forward to install all three components on 64 bit Windows 2008 server?
Issue with AutoDesk India - No clue on any issue!!!
Anand
3 REPLIES 3
Hi Anand,
can't remember the details anymore but Studio is a sperate installation package. You didn't mention why Studio wasn't installed - did you run Studio installer? It should be in a subfolder in the installation image für AIMS.
Studio is a client application - you wouldn't install it on a server but on a client such as XP or Win 7 machine.
Rob
http://raumpatrouille3d.blogspot.ch/
Yes Rob,
AIMS 2012 contain all modules together and selectable to install sometime. However, as you suggested, I have installed studio separately and it has done.
Thanks really
Furthermore, now I and getting another message while login to Studio:
Message is – FastCGI must be properly configured before attempting to connect to Map Server. Any light on this please?
Anand
Hi Anand,
regarding the error message - I put the follwing into Google and got a (promising) hit: ""FastCGI must be properly configured" mapguide".
http://adndevblog.typepad.com/infrastructure/2012/04/install-autodesk-infrastructure-map-server-2013...
If it doesn't help to solve the problem - read through the AIMS Installation&Configuration Guide and check if everything has been installed properly. If the issue persists open a new thread in the discussion list,
Rob
”Boost
