Hi everyone, I'm posting for one of our users...Please advise a way of saving the 'Map Coordinate System' on a specific drawing? - For example, I need to use Coordinate System MGA-55 when working on an Australian Project, and UTM84-39N when working on a Kazakh Project, however, if I set my coordinate system to MGA-55, then save my drawing, the Coordinate system resets to UTM84-39N when I reopen the same drawing (it appears not to be saved with the drawing). I'm Using 'AutoCAD Map 3D 2012 (64bit) running on Windows 7. Thanks!
Solved by antoniovinci. Go to Solution.
Before saving, try to force the current CRS thru the _ADESETCRDSYS command, sir.
Hi antoniovinci
Email from my very satisfied colleague...
"This post has provided the solution, and I am now able to set templates for the various Projects I work on. Thanks very much for your assistance."
