Is there a way to sent print to a selected printer by choosing multiple dwg files thru Folder directory without opening autocad? For example if I want to print 12.dwg, 13.dwg, 14.dwg and 15.dwg by just choosing these dwg files on my directory. Thanks in advance.
No, there are too many parameters to set when printing a dwg files, such as layout, page setups, scale, etc. but once you open AutoCAD you can use the publish command to print them with out opening each one first.
