AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Please help me The plot is inconsistent with the map view labels overlap
3 REPLIES 3
700 Views, 3 Replies
Hi, I have a problem with Autocad Map 3d 2009.
When I print or preview, dynamic labels overlap
  and do not coincide with screen view.
Is there a command or variable that controls this display?
I have installed all available updates.
What is the problem?
Why do not match.?
3 REPLIES 3
Alfred.NESWADBA
There are so much types of what "labels" can be, what are you speaking about?
An additional screenshot might also help to identify what you are speaking about.
Global info: if lables overlap use either another plot-scale or another label-/textsize (or not all labels are shown/printed)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
hi Alfred
I put two examples.
if you click on my nickname  "v.almenar" (about v.almenar) you can see in the pictures section,
two catches in Spanish.
Example 1 => screen view
Example 2 => preview view or print to pdf
The result is identical print to pdf with adobe pdf, Bluebeam, autocad dwg to pdf.
The screen look good and when printing overlap.
Not normal.
It is for the printer or the program Autocad map 2009 ?
thanks you,
sorry, do not know how to attach the images properly.Ejemplo1.PNGEjemplo2.PNG
Alfred.NESWADBA
ok, I have also a screenshot (in German 😉 ) and you see there the dialog for FDO-stylization. There are two checkboxes (in case of the data is point-like), play with the checkboxes and see how the labels reposition themeselves.
HTH, - alfred -
Alfred NESWADBA
”Boost
