I have received a DWG with plain CAD objects e.g. open polylines (defining linear water features) and closed polylines (defining land use areas) and I need to use this info in map for buffer/overlay analysis.
How do I go about preparing this data for use in MAP as described
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by Murph_Map. Go to Solution.
Assuming that it has been MAPCLEAN'ed - how do I get it into map layers/themes etc
Will give these a try - thanks
Mapexport to SDF or SHP format. Then data connect to that data.
OR
Connect to a new blank sdf and select create new feature from geometry.
How do I "...Connect to a new blank sdf and select create new feature from geometry."
Thanks for this Murph - I'll play around with MAP/CAD entities and see how far I get
