AutoCAD Map 3D General
Distinguished Contributor
olivier.eckmann
Message 1 of 6 (160 Views)
Pb with command _MapPolylineToPolygon
160 Views, 5 Replies
11-28-2012 07:54 AM
I've MAP 3D 2013 64 bit (French version) with SP1.
When I launch command to "Convert polyline to polygon" (_MapPolylineToPolygon), I've message on command line "Select objetcs", I can convert to polygon =>OK
If I launched this command a second time, I've no possibility to select object, I come back to command line.
I quit MAP, then launch MAP, and I can use this command only 1 time.
This problem appears after SP1 was applied.
Could someone reproduce this problem? Have you got a solution?
thanks
Olivier
antoniovinci
Message 2 of 6 (149 Views)
Re: Pb with command _MapPolylineToPolygon
11-28-2012 11:20 PM in reply to: olivier.eckmann
I can't, since I'm a poor 2006 user, but... what about using the _MPOLYGON command instead?
Alfred.NESWADBA
Message 3 of 6 (133 Views)
11-30-2012 02:23 AM in reply to: olivier.eckmann
already confirmed >>>here<<<.
(you would have found by yourself using the search >>>click<<<, currently the second item of the list of found links :smileywink: )
- alfred -
Alfred NESWADBA
olivier.eckmann
Message 4 of 6 (118 Views)
11-30-2012 12:39 PM in reply to: Alfred.NESWADBA
Sorry for not searching before posting.
Olivier
Alfred.NESWADBA
Message 5 of 6 (116 Views)
11-30-2012 12:46 PM in reply to: olivier.eckmann
No problem :smileywink:
- alfred -
Alfred NESWADBA
olivier.eckmann
Message 6 of 6 (103 Views)
12-04-2012 04:13 AM in reply to: olivier.eckmann
Hotfix has been published to correct this problem.
HotFix
Olivier
You are not logged in.
Ask the Community
