I've MAP 3D 2013 64 bit (French version) with SP1.
When I launch command to "Convert polyline to polygon" (_MapPolylineToPolygon), I've message on command line "Select objetcs", I can convert to polygon =>OK
If I launched this command a second time, I've no possibility to select object, I come back to command line.
I quit MAP, then launch MAP, and I can use this command only 1 time.
This problem appears after SP1 was applied.
Could someone reproduce this problem? Have you got a solution?
thanks
Olivier
olivier.eckmann wrote:Could someone reproduce this problem?
I can't, since I'm a poor 2006 user, but... what about using the _MPOLYGON command instead?
already confirmed >>>here<<<.
(you would have found by yourself using the search >>>click<<<, currently the second item of the list of found links 😉 )
- alfred -
No problem 😉
- alfred -
