AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Pasted Excel Table in Map 3D 2011 - Text Disappears for Second User
2 REPLIES 2
462 Views, 2 Replies
I created some tables in the attached AutoCAD Map 3D 2011 drawing by copying and pasting cells from an Excel 2007 workbook.
I have been able to update the tables in AutoCAD and print without any problems. However, when a second user opened the drawing, the table text was missing (the lines were present).
Any idea what may be wrong with the drawing and how to fix it?
Note: We are saving our files in AutoCAD 2010 format for compatibility with some LT users.
2 REPLIES 2
thepworth
Do both machines have the same level of ODBC drivers installed?
Check Control Panel - Administrative TOols - Data Sources - Drivers Tab - see if the version is the same for both.
in reply to: thepworth
I'm running Windows 7 64-bit and he is running Windows XP. I will check on the drivers.
”Boost
