AutoCAD Map 3D General Discussion
Murph
Message 11 of 17 (221 Views)
Re: Overlay Analysis
04-29-2013 04:58 PM in reply to: engrtech
Set your feature edits options to "Check out Features as AutoCAD enities. Then use the Query To filter data, select locate on map then pick inside or touching polygon, Ok. When it asks for the polygon use the select option and pick on the flood zone polygon feature. Then save the selected layer to a new SDF file.
Murph
Supportting the troops daily.
Valued Mentor
engrtech
Message 12 of 17 (207 Views)
04-30-2013 05:05 AM in reply to: Murph
I saw where I can use a single polygon to do the selection. The problem is there are a lot of polygons that make up the flood zones. Do I have to do a OR statement for every single polygon that makes up the flood zones? If so, then no wonder ESRI is so popular considering this should be a basic GIS function.
Infrastructure Design Suite Premium 2014
Civil 3D 2014 x64
Testing IDSP 2015
Windows 7 64-bit
6GB RAM
Valued Mentor
parkr4st
Message 13 of 17 (198 Views)
04-30-2013 12:03 PM in reply to: Murph
like so
[LOCATION:INSIDE.POLYGON.ID1] OR [LOCATION:INSIDE.POLYGON.ID2] OR [next location etc.
Valued Mentor
engrtech
Message 14 of 17 (192 Views)
04-30-2013 12:20 PM in reply to: parkr4st
parkr4st wrote:
like so
I might as well just wait on our GIS division to do it since they use ArcGIS. I'm not going to manually select each and every polygon. That defeats the purpose of a query in the first place. Why not just count them by hand if that's the case?
Civil 3D 2014 x64
Testing IDSP 2015
Windows 7 64-bit
6GB RAM
Distinguished Contributor
olivier.eckmann
Message 15 of 17 (187 Views)
04-30-2013 01:33 PM in reply to: engrtech
It's easy with MAP to do what you want.
I'm not sure of english terms (I use french version)
1. make a GIS overlay : source = WATER, target = BUILDING, mode intersection
=> you obtain a new layer WATER_INTERSECT which has minimum 2 fileds : FeatID_WATER and FeatID_BUILDING
2. edit BUILDING table and make a join with WATER_INTERSECT layer by using corresponding keys : FeatID on BUILDING table and FeatID_BUILDING on WATER_INTERSECT table
=> you obtain 3 new field on each BUILDING, and one of this field is FeatID_WATER which is NULL if building is not in WATER_INTERSECT which means this building is completly out of water.
3. Make your thematic on this WATER_INTERSECT|FeatID_BUILDING which is NULL or NOT
Olivier
Valued Mentor
engrtech
Message 16 of 17 (183 Views)
04-30-2013 02:04 PM in reply to: olivier.eckmann
Olivier
Doing it that way worked. Thanks! It still seems very involved for something that should be pretty simple.
Civil 3D 2014 x64
Testing IDSP 2015
Windows 7 64-bit
6GB RAM
Valued Mentor
parkr4st
Message 17 of 17 (167 Views)
05-02-2013 02:29 AM in reply to: Murph
even easier
get your buildings on the map
draw a polygon away from the buildings
mapexport to a sdf & add to map
on an empty dwg layer draw all the selection polygons over the buildings as you need / want them
go to the sdf in Display manager and rc / select new feature from geometry and select all the polygons and ok
you can now use that data as your areas for selection as selecting any polygon will select all of the polygons as one sdf data item
and your sdf can be put into the map anytime you need to run the query again such as after you add or delete buildings.
dave
You are not logged in.
Ask the Community
