AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Ordnance Survey VectorMap
8 REPLIES 8
Message 1 of 9
bill.smoker
1795 Views, 8 Replies
Has anyone out there (UK or eslewhere) come up with a workable way of importing Ordnance Survey VectorMap into AutoCAD Map3D yet?
http://www.ordnancesurvey.co.uk/oswebsite/products/os-vectormap-local/index.html
The OS is due to discontinue its10K raster mapping, and it would be good if CAD users were not excluded from using this base mapping in future.
Bill Smoker
Senior CAD Technician
London Borough of Hammersmith & Fulham
8 REPLIES 8
Message 2 of 9
ChadRoberge
in reply to: bill.smoker
I have not had to do it, but I have imported GML data by importing it into an SQL database.  I can then use autocad to connect to the SQL data base to produce the maps.
Message 3 of 9
bill.smoker
That is pretty much the way I deal with MasterMap data from the OS. Unfortunately, VectorMap seems to be a different 'flavour' of GML, and Map stuggles to read it. I have had no luck so far with the sample data I have.
Message 4 of 9
phil_borycens
Hi Bill,
Can you describe your workflow for importing the GML data, and how Map 3D "struggles" with the process? Please be as specific as you can.
Also, what's the easiest way for me to get a free sample to test this process? Can you provide me yours, or should I sign up for their Discover Data Licence?
In regards to a similar product, the OS MasterMap, another specialist here suggested this, which might also apply to VectorMap:
one possible workaround I have found is to import the file by choosing the GML format instead of the OS Mastermap in the MAPIMPORT dialog. In this way the file will be imported although it will be imported by feature type (Lines, Polylines etc) and not by OS layer.
Word on the street says that there is a tool out there for translating the OS file into an ESRI shapefile...if this is true, then you could use this tool, then run a MAPIMPORT or connect to the shapefile using FDO.
Of course, I am in the United States, so what do I know? 😉
Anyway, I look forward to your reply.
Phil
Phil Borycens
Message 5 of 9
Hi
Has anyone had any luck with this? I tried to MAPIMPORT using the alternative gml import without success.
I had heard there were converters but have not found one yet.
Fran
Message 6 of 9
bill.smoker
As suggested by Phil above, the workaround is to convert to ESRI shapefiles using Rolta Vector freeware http://www.rolta-europe.com/osvector.html and then import the shape files. This seems a clumsy way of approaching the problem, and I am disappointed that Map 3D 2013 is still unable to import this 'flavour' of GML. Also, I am struggling to extract any useful text labels from the shapefiles, though that may just be a lack of knowledge on my part. For the time being, I am sticking to using the old-fashioned TIFF files for 1:10000 mapping. It's a shame to miss out on the flexibility of vectorised data.
Bill
Message 7 of 9
Hi
Thank you for your reply, I had downloaded the Rolta Vector freeware last night. Tried it today without success initially as I have a 64bit machine. Using a 32bit machine the convertor was great. The text, I imported as points using the 'Create as text from data' option in the point mapping dialogue box. I used the data "textstring". The text has appeared now on the screen as mtext; I assume now I will be able to edit it in the normal way. Not sure if that will help with the problem you were having? Smiley Happy
Lets have some of the vector flexibility; Happy Importing. 🙂
Frances
Message 8 of 9
I have got that far, but the text is not sized or rotated. I will dig a bit further, I'm sure it must be feasible.
Bill
Message 9 of 9
TerryDotson
For anyone looking for additional options (including the need to import into plain AutoCAD), the MapWorks Base module will import multiple OS MasterMap files in .GML or .GZ format.
”Boost
