Joel hi,
I think I have an idea that might be helpful.
When you build your Database, make two tables:
1- The first one will be the table that has in it all the drawing
object's information, including the key field (or fields).
2- The second table will include the information that is added to your
AutoCAD objects.
The two tables can be linked in the way you need: for example, one-to-many.
Then, define a query that includes the needed information from both tables.
Don't forget to include the key fields.
Back in Map you can now link your objects (Just as always) to this query by
defining a new Link Template that is
just like the original one (But a different name, of course).
You can now query your objects on the basis of the information in this
query.
This way you do not have multiple instances of the same information in the
database and it is much easier to update that info.
(Beware: you cannot edit the information in this query from Map, you can
only view it or query by it.)
Good Luck,
Arad
"Marion Pietsch (Autodesk)" wrote in
message news:3BA9DFEF.1F59B650@autodesk.com...
> Joel,
> in general you should be able to link 800 objects to 13 rows in the table,
but I
> wouldn't recommend doing this, because for most features to complete a
unique
> key/record is needed.
> Map was not designed to work with 'lookup tables', even if you could use
them
> for querying tasks.
> Reading thru the following instructions I starting writing up for using
lookup
> tables for queries in Map might give you some ideas what is
possible/recommended
> and what not even if it won't answer your question exactly.
> Imagine you have 2 tables in one MS Access mdb file where only one (called
> 'first table') is linked to drawing objects; the second table (called
'second
> table') is only linked to the first table by a common column.
> In Map you can query data also from the second table by using the syntax
> described in the following scenarios in all commands that offer an SQL
> 'Expression' option, for instance in Map > Query > Define Query > Alter
> Properties.
> Scenario 1
> You could now query values from the second table in the mdb file by using
the
> following expression:
> &SecondTableName.ColumnNameToQuery@LinkTemplateNameForFirstTable
> This would just query all entries from the specified column name of the
second
> table, but that's probably not really what you're looking for, because
there's
> no connection to the table that is linked to the obects whereas with a
lookup
> table there's a (one-to-many) relation between the
> tables.
> Scenario 2
> To get only the records from the second table queried that are linked to
the
> first one you'd need a column that exists in both tables (with the same
name and
> field type). The expression would then be:
&SecondTableName.ColumnNameToQuery@LinkTemplateNameForFirstTable.LinkingColu
mnName
> Scenario 3
> Now, if the column name that links the 2 tables doesn't have the same name
you
> have to specify the corresponding field names in the expression:
mnNameInFirstTable.LinkingColumnNameInSecondTable
> And finally, if the tables are not in the same scheme and/or catalog you'd
have
> to define it for the second table on the left side of the @:
> &Catalog.Scheme.SecondTableName.ColumnNameToQuery@......
> Summary:
> This means that you can use lookup tables with all Map functionalities
where SQL
> Expressions are allowed. That works e.g. for reports, but in the drawing
itself
> when working with drawing objects and the DataView the linkage between the
2
> tables is not available for use (for example
> it doesn't work to highlight a row in the lookup table and get all linked
rows
> in the actually linked/first table highlighted, or even more also the
linked
> objects in the drawing).
> Marion Pietsch
> WW Support & Services
> Autodesk GIS Product Support
> Joel Zimmerman wrote:
> > I have a polygon topology that has centroid object data. I want to link
the
> > topology to an Access 2k table with a link template. When I do so I only
get
> > some of the centroids linked. The data table only has 13 rows. Each
piece of
> > the 800+ object data can be linked to one of the table rows. When I
attempt
> > this I get 51 links and the others cannot be processed. They match
exactly.
> > When I use the "Convert Object Data to Database Links" tool I get a
table
> > with 800+ rows. Most of this data is duplicated. I want a lookup table
that
> > has a One to Many relationship and not a reference table that has a One
to
> > One relationship.
> > Any Ideas?
> > Joel
> > joel@NSPM.harden-assoc.com
> > remove the NSPM. to email me directly
