Sounds like to me that there are OD tables in the template that you are
using to start with. Open a NEW dwg and type (ade_odtablelist) at the
command line, if there are no tables it should return NIL.
Murph
"kb" wrote in message
news:1443982.1110314957941.JavaMail.jive@jiveforum2.autodesk.com...
> Alright, now I'm really confused. I just opened a blank drawing and
attached the same drawing in 2004 that wasn't yet updated. It attaches fine
with no errors. However, using 2004 and attaching the updated 2005 drawing
I get the error of conflicting tables.
> So, with that said, what is causing the problem? I open up the 2005
drawing, and there are two object data tables with unique names. There is
no object data tables in the blank session I'm opening. I've ran an audit,
a recover, and purged the drawing without success.
> I'm quickly running out of ideas.
