Can someone walk me thru how to assign Object Data from a linked External Database.
1. I have a drawing of a Sewer Network which contains Object Data. One of the OD field is defined as PIPE_ID and each line in the Pipe network has a unique PIPE_ID value (which is text, not a number).
2. I also have a Access File (.mdb) that contains just 2 columns. Column #1 is the Primary key and has a heading of PIPE_ID and is populated with some of the same PIPE_ID's as the Object Data Table. Column #2 has a heading of INSPECTION and is populatd with various text values.
3. How can I add the column #2 (Inspection field) from the Access table to Object data in my drawing?
I just don't understand the steps it takes to do this.
Paul
P. Graf
C3D 2009 & 2010
Windows XP
3 GB ram
intel Core 2 Duo
ATI Radeon HD 2400 Pro
