AutoCAD Map 3D General
Member
mlain001
Message 1 of 5 (274 Views)
Accepted Solution
OSNAP asking for integer from 1 to 30
274 Views, 4 Replies
04-03-2013 08:10 AM
We have a drafter who's Map 3D 2013 Drafting Settings dialog box is giving him a pop up that says "Please enter an integer from 1 to 30".  He is able to set osnaps and others thru quick keys and other methods, but going through the dialog settings dialog box is generally the easiest way to go.
If anyone knows what is happening or how to fix it, please let me know. The only button that seems to work is the cancel.
Michael.
*Expert Elite*
braudpat
Message 2 of 5 (249 Views)
Re: OSNAP asking for integer from 1 to 30
04-03-2013 12:03 PM in reply to: mlain001
Hello
Just an idea :
Could you check the SNAP Tab and its X/Y values ...
Try to disable SNAP with F9 ?
Bye, Pat
Bye, Pat
Active Contributor
shunter62
Message 3 of 5 (227 Views)
04-04-2013 10:00 AM in reply to: mlain001
From the Help menu:
http://docs.autodesk.com/CIV3D/2012/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-4f1d.htm
This describes osnap settings.
HTH,
Susan H
Distinguished Contributor
olivier.eckmann
Message 4 of 5 (216 Views)
04-05-2013 01:13 AM in reply to: mlain001
this message is due to a wrong parameter, but not in OSNAP tab, but in QUICK PROPERTIES Tab.
It's the number of rows in in the quick properties palette wihich must be between 1 and 30 .
Even if you are on OSNAP tab, when you click OK, all values in ALL tabs are verified.
Olivier
Member
mlain001
Message 5 of 5 (195 Views)
04-08-2013 08:47 AM in reply to: olivier.eckmann
Thanks, Olivier, that was the exact problem.
You are not logged in.
Announcements
Need installation help?
Ask the Community
