AutoCAD Map 3D General
Member
rangercap
Message 1 of 4 (121 Views)
Numeric Value Labels in MAP 2013
121 Views, 3 Replies
04-19-2013 08:50 AM
Hopefully this is fairly simple to answer:
I have numeric values [St_NUMB] I'm adding as labels. I see that Map is converting them to strings [TOSTRING"(ST_NUMB)"]. The ST_Numb refers to a street number for a a house, and any outbuildings are labels as '0' (zero) since they are not technically an addressable structure. I have a large amount of data with a value of '0' (zero) that I would like to filter out of the labels. I'm really not sure what expression or command is the simplest to use.
Thanks in advance.
Brian
*Expert Elite*
braudpat
Message 2 of 4 (116 Views)
Re: Numeric Value Labels in MAP 2013
04-19-2013 09:51 AM in reply to: rangercap
Hello
In your SDF, SHP, SQLite, Oracle, etc Table, the ST_NUMB Field is :
Number/Interger?
OR
Character/Varchar ?
Have you some A-Z chars (or other non numeric chars) after the numbers ?
Some samples (as I can imagine) : 0123 , 00456A , 00789 AB , etc
Bye, Pat
Bye, Pat
*Expert Elite*
Alfred.NESWADBA
Message 3 of 4 (94 Views)
04-20-2013 06:16 AM in reply to: rangercap
create two rules in the display manager, the first with the filter-expression St_NUMB = 0 (that does not show a label) and the other as the default "Standard".
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Distinguished Contributor
olivier.eckmann
Message 4 of 4 (88 Views)
04-20-2013 02:44 PM in reply to: rangercap
in the label, you can use this expression
 If ( ' St_NUMB = 0 ' , '', ToString ( St_NUMB) )
Olivier
You are not logged in.
Announcements
Need installation help?
Ask the Community
