AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Numeric Value Labels in MAP 2013
3 REPLIES 3
323 Views, 3 Replies
Hopefully this is fairly simple to answer:
I have numeric values [St_NUMB] I'm adding as labels. I see that Map is converting them to strings [TOSTRING"(ST_NUMB)"]. The ST_Numb refers to a street number for a a house, and any outbuildings are labels as '0' (zero) since they are not technically an addressable structure. I have a large amount of data with a value of '0' (zero) that I would like to filter out of the labels. I'm really not sure what expression or command is the simplest to use.
Thanks in advance.
Brian
3 REPLIES 3
braudpat
Hello
In your SDF, SHP, SQLite, Oracle, etc Table, the ST_NUMB Field is :
Number/Interger?
OR
Character/Varchar ?
Have you some A-Z chars (or other non numeric chars) after the numbers ?
Some samples (as I can imagine) : 0123 , 00456A , 00789 AB , etc
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Alfred.NESWADBA
create two rules in the display manager, the first with the filter-expression St_NUMB = 0 (that does not show a label) and the other as the default "Standard".
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
olivier.eckmann
in the label, you can use this expression
 If ( ' St_NUMB = 0 ' , '', ToString ( St_NUMB) )
Olivier
”Boost
