AutoCAD Map 3D General
Member
EBHShawRedMt
Message 1 of 8 (1,805 Views)
No layer properties dialog box
1805 Views, 7 Replies
04-29-2011 01:35 PM
Hitting the layer properties button puts it in "cursor" type mode.  No dialog box appears.  Think a computer crash reset a bunch of settings.  Any way to get dialog boxes back?  Can't find it in "options"...
Murph
Message 2 of 8 (1,800 Views)
Re: No layer properties dialog box
04-29-2011 03:47 PM in reply to: EBHShawRedMt
With out know what version and system specs start with the starndard fixes.
Filedia = 1
Cmddia =1
Murph
Supportting the troops daily.
Member
EBHShawRedMt
Message 3 of 8 (1,797 Views)
04-29-2011 03:54 PM in reply to: Murph
Sorry - PC, Windows 7.  Map 3d 2012.  Already tried those settings - they were set to 1.  Still doesn't work.
Murph
Message 4 of 8 (1,793 Views)
04-29-2011 04:00 PM in reply to: EBHShawRedMt
LAYERDLGMODE
Is it all palettes that fail to display or just the layer property manager palette?
If it's all the palettes (properties, Xref, SSM etc) then it might be a dot net framework issue.
Murph
Member
EBHShawRedMt
Message 5 of 8 (1,791 Views)
04-29-2011 05:25 PM in reply to: EBHShawRedMt
It's the dialog box itself.  No dialog box.  The individual commands pop up next to the cursor in a list, just as if you had typed pedit in the command line.  There is no dialog box.  THink I need to reinstall Autocad...
COLINBIBLE4464
Message 6 of 8 (1,764 Views)
05-04-2011 06:33 PM in reply to: EBHShawRedMt
Try this:
1. Press Alt and the Spacebar at the same time, and then let go
2. Press the letter M
3. Press the UP arrow
4. Move your Mouse around and you should see the dialog. Click for the dialog to stay.
Hope this helps.
Original post by Matt Kolberg in 2009
Member
EBHShawRedMt
Message 7 of 8 (1,752 Views)
05-05-2011 06:05 PM in reply to: EBHShawRedMt
Had already tried that one - good news is somehow the installation had been munched.  Reinstall solved everything.
Thanks for all the help.
New Member
jbuffie
Message 8 of 8 (1,350 Views)
07-19-2012 01:52 PM in reply to: EBHShawRedMt
I had the same problem and tried the same solutions (except reinstall) with no luck.
What worked for me was changing my saved workspace to one that had the dialog box open.
So far so good.
You are not logged in.
Ask the Community
