We have an AutoCAD Map 3D - 1 License,
There is a need to migrate this license from the existing server(Windows 2003) to another server(Windows 2008).
Can you please outline the process.
Hi ACAD_FWIPLEAG !
If the server name and mac address are changing, you will need to use a new license file that I can generate for you.
If this is the case, you can send me your serial number and server details by private message (click the envelope next to your name)
Thanks!
I have a similar situation to the original poster except I have the license file on the new server. What I need to know is how do I change existing installs to see a new license server, or an additional license server. I have tried adding the environment variable but that makes no differnce. I have tried editing the LICPATH.LIC file and that had no effect either. I have several installs of CAD, MAP, Plant, P&ID and don't want to have to remove and reinstall them if possible.
Thanks for any insight.
The ADSKFLEX_LICENSE_FILE will work if you do it right. Make sure it is a system variable and not a user variable.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8385605&linkID=9240617
Also, stop the other license manager. If the client cannot find the NLM, it will prompt for the location. You don't need to reinstall.
Thanks for the encouragement. As I worked through this I found that the Environment Variable creates a registry key under HKey local user. The reason the EV wasn't working when I would change it is that the reg key was there already. When I deleted the registry key and ran Map3D again it read the EV and created the key. From there I was able to create a registry hack file to put in the license servers I wanted. The install still looks for the old server first, regarless of order in the EV or the reg, but it works when I take either server off line it goes to the other. This is the .reg file I used to insert the values.
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\FLEXlm License Manager]
"ADSKFLEX_LICENSE_FILE"="@NewServer;@OldServer"
I'll test more on new installs as well, but this is what I found to work.
Make sure your PING to the new server by hostname yields an IPv4 address and not an IPv6 address. This could be your culprit.
