AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Network Topologies: how to represent bridge/tunnel?
2 REPLIES 2
397 Views, 2 Replies
Is there a way of attaching connectivity data to nodes in a network topology?  For example, a bridge where two roads cross might be represented by four polylines A, B, C, D with endpoints coinciding where the bridge is.  How would you represent the fact that A joins C and B joins D but A does not join B/D and B does not join A/C?
2 REPLIES 2
daniel.jurado
Have you tried changing the elevation on one of them.
Olga_Shevchenko
First of all you needn't create nodes, where the traffic streams are not crossed.
HERE is a video showing two choices running of Network Analises: A - with a bridge or an overpass> B - with a road's intersection at the same level.
”Boost
