I'm trying add a feature label to a polygon feature with an if/then expression that will display the NAME field only when the STATUS field = A. I'm kind of new to this so haven't been able to figure an expression out.
Solved by parkr4st. Go to Solution.
select the layer in display manager
style
add a rule STATUS = A
Feature Label set to Name
leave the default without a label
you can also set the style to a different fill(s)
