Hello Everyone,
I have a list of trajectories as CSV file, it contains XY coordinates in meter and Depth in feet, is there a way to customise Autocad Map to have the multi units coordinate system(Planar unit: meter, Vertical Unit: feet)?
I loaded the data into global mapper by specifying the depth as feet then I exported it as shapefile, but when I import it into autocad map i got the right dpeth values but in meters not in feet,
Regards
