AutoCAD Map 3D General Discussion
Active Member
gisstat
Message 1 of 5 (335 Views)
Merging mpolygon
335 Views, 4 Replies
05-23-2013 11:51 PM
The data is being imported via FDO connection from oracle spatial, so we use MPolygon objects in the Map 3d 2013 drawing. So the new polygonal objects are created by mpolygon tool. While we use command “mapmpedit - Add” to merge two polygons, the result polygon seems to be made of two polygons (we can see common lines of original polygons), although it’s being selected as single object. Are there any ways to solve this problem, so we could obtain single polygon without of any additional lines in the places of joining.
*Expert Elite*
antoniovinci
Message 2 of 5 (331 Views)
Re: Merging mpolygon
05-24-2013 12:23 AM in reply to: gisstat
Could you attach here 2 of those adjacent mpolygons..?
Please _WBLOCK in 2004 format, so I'd be able to manage 'em.
Valued Mentor
gluckett
Message 3 of 5 (318 Views)
05-24-2013 04:22 AM in reply to: gisstat
*Expert Elite*
Murph
Message 4 of 5 (314 Views)
05-24-2013 04:36 AM in reply to: gisstat
As Gordon reply use the mapfeaturemerge command. If you are using FDO and connecting to the features then try to use mapmpedit on them it is checking the features out and converting (making a copy) of them as AutoCAD enities. What you may be seeing is both the orginal features from the FDO connections and the new mploygons. If you turn off the FDO layer from the display manager do you see the single mpolygon?
Murph
Supportting the troops daily.
Active Member
gisstat
Message 5 of 5 (301 Views)
05-24-2013 09:01 AM in reply to: Murph
If I select two objects MPOLIGON and use MAPFEATUREMERGE command, I get the message "You must select at least two objects, one of which must be a feature". Oracle database is disconnected, mpolygon objects stored in dwg file.
You are not logged in.
Announcements
Need installation help?
Ask the Community
