Hi, I'm trying to use split/merge rules in ACAD Map 2013. The rules are working only in the split cases, when i try to merge, the features merge but the data don't follow the rules. I tested it connected to Oracle DB, SDF and SHP, it's the same problem with the 3 origins.
When i use this tool in ACAD MAP 2014 or 2012 it works fine.
Any help will be appreciated.
Hello
Welcome to the Autodesk/AutoCAD Forums !
Just a "stupid" question : have you installed the SP 2.1 on your MAP 2013 ?
You said : it's OK with MAP 2012 and with MAP 2014
Please is it possible to have an extract (SHP or SDF) of the files and a DWG with FDO layers and your rules ?
Patrice BRAUD
Thanks for being there Braudpat. We actually have installed the sp 2.1, i'm attaching an example. I've already tried changing CS and rules too.
Hello
OK I get your DWG + SDF file ...
So I imagine that you are trying to merge polygons based maybe on the common MANZANA attribute ?
Or what else ??
Patrice BRAUD
Hi Braudpat, we're trying to merge poligons that share one side, they're parcels, we use to merge them because they are unificated in terrain and legally. And we need to retain the name (parcela) of the merged parcels concatenated with a "-".
Thanks for your help.
