AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
MapExport Cogo Points (Data) to ESRI??
1 REPLY 1
DaveMartin4189
1124 Views, 1 Reply
I've got Cogo Points, collected with a GPS unit, (in Civil 3D v2013) representing Valve Vaults and Fire Hydrants for a city.  Each point contains Property Data (full description) that represents its structure number.  I need to transfer this data with the point into ESRI .shp files.
In using the MAPEXPORT command, choosing 'Points.... when I go to the Data tab > [Select Attributes] button, I don't see where to select the Description attribute, which holds my structure number data.
Is there a way to specify that this (structure number) data be exported during MAPEXPORT command?
Thanks in advance,
Dave
ps: the attached file has a screen shot-  showing Properties of my Cogo Point
Tags (1)
1 REPLY 1
why not using the Civil3D point export, that creates a (structured) ascii-file which is good enough to be imported in ESRI products. MAPEXPORT does not have access to C3D-internals.
Try it, command is: _AECCEXPORTPOINTS
Viel Erfolg, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
