AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map3D 2013 tutorial
4 REPLIES 4
Sam-I-am
1318 Views, 4 Replies
Map3D 2013 tutorial
In Tutorial: Working with Industry Models
Exercise 2: Import Data into the Industry Model,
I am supposed to go to the insert tab and run convert to industry modle.
however it does not exist in this tab, I could not get the help file to show be where I could find this command.
any suggestions
also where is the dataset for this module. I followed the link from the help file to
http://docs.autodesk.com/MAP/2013/ENU/ but could not see any data set for this module
4 REPLIES 4
baudins
in reply to: Sam-I-am
You have to be in the "Maintenance Workspace" to be able to see the "Convert to Industry Model":
For your second question, you can find some template under:
...\Program Files\Autodesk\AutoCAD Map 3D 2013\Sample\
Kind Regards,
Sébastien Baudin
Autodesk Support Team
jaynejw
I checked my dataset for industry model tutorial
:\Program Files\Autodesk\AutoCAD Map 3D 2013\Sample\Maps\SDF
those data is not match the Exercise 2: Import Data into the Industry Model. I don't have CONDUCTOR.sdf and SERVICE_POINT.sdf and TRANSFORMER.sdf
DO anyone know where I can find those data files ?
g-eaux
in reply to: jaynejw
I've the same problems with tutorials :
i spend much time searching for files than to follow the tutorial.
But for that files, conductor and service point, i don't find theme, so i can't go on.
Can Autodesk put alla theses files on the web for download ?
Alfred.NESWADBA
in reply to: g-eaux
have you found >>>that site<<<?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
