I have Map3D 2010 and Civil3D 2010 installed on the same box. I was using C3D to print maps that contained MrSID Images. This worked flawlessly for months - today it froze. I waited almost an hour and then shutdown the process manually and restarted. Now I can not use C3D or Map3D - I get this fatal error message: FATAL ERROR: Unhandled Delayload "acdb16.dll" Module Not Found Exception at 7c812afbh.
I have repaired and then reinstalled C3D - same error. I then uninstalled Map3D completely and reinstalled fresh with SP1 - same error.
I'm stumped - anybody have an idea what I can do to get this working.
Tom
