AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map/Image/Insert
2 REPLIES 2
mcloughlin
4292 Views, 2 Replies
Map/Image/Insert
When attempting to insert an .ecw image via map/image/insert, I receive in the command line this response:
   No entry for MAPIINSERT was found.
   No entry for AECIEXTMARSHALL was found.
This is Map 2008.
How do I insert a georeferenced .ecw image into Map 2008?
Many thanks.
2 REPLIES 2
even if I havn't seen these messages .... when having problems using ECW-files I always install the RasterDesign-ObjectEnabler from >>>here<<<
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
antoniovinci
in reply to: mcloughlin
Well, you have two ways: _MAPIINSERT and _MAPCONNECT
Try to load my attached .ECW (by the way, I use Map2006 without any problems with them).
If it doesn't work even with my sample map, we're gonna investigate deeper.
”Boost
