AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 3D 2013 Labels not Displaying when Plotting/Exporting
3 REPLIES 3
TomWilgaWH
617 Views, 3 Replies
I've searched this Discussion Groups area on the site and have found a couple solutions. I've tried them all but I can't seem to figure out how to get ALL of my labels to display when I plot or when I export to PDF. It seems that only the POLES layer labels are having trouble showing up...
I understand scaling and it doesn't seem to be the issue. I've tried plotting under different scales, and I still get the same thing.
I've attached an image showing the outcome.
On the left is the PRINT PREVIEW in AutoCAD.
On the right is the EXPORTED PDF.
I've checked in the administrator under POLE LABELS, and changed a couple things around but I can't seem to get the pole labels to show up.
Any ideas?
Thanks in Advance,
Tom
Welland Hydro
Thomas Wilga
Engineering Technician
GIS Coordinator
Field Inspector
Welland Hydro-Electric Systems Corp.
3 REPLIES 3
fieldguy
in reply to: TomWilgaWH
Assuming your are using the autodesk dwgtopdf driver, have you tried changing the font info (see attached)?
Murph_Map
Have you tried this one?
Murph
Supporting the troops daily.
braudpat
in reply to: Murph_Map
Hello
+1 with Murph !
This limitation is historical and too low !
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
