AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 3D 2006 Unexpectedly Quits and Disappears
0 REPLIES 0
Message 1 of 1
ELIINC
274 Views, 0 Replies
Hey all - I need some help.
I have installed and reinstalled map 3D 2006 more than three times now each time making sure that this is not user error. Whenever I insert an xref or an image I can successfully get it into a drawing but the second I click on anything - a line, the xref, a command button - AutoCAD just disappears.  No "fatal error", no warning message, do not pass go do not collect $200.00.  It literally just closes as if I unplugged it's power source.
These are occasions that this happens:
- Inserting xrefs
- Inserting Images
- File Save As drawings (I can open a dwg and the cntl + s, just fine)
- Opening a drawing after a crash (loads 90% then crashes again)
- Loading or Changing Layer States
If I insert something and then quick save... let it crash and/or close cad completely - When I reopen CAD I can click on anything and move, scale whatever, just fine.
This is driving my insane. Any advice?
0 REPLIES 0
”Boost
