AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 2012
4 REPLIES 4
522 Views, 4 Replies
Map 2012
When I open map 2012 the 2d drafting workspace comes up.  How can I get it to open into the map classic workspace.
Joe
4 REPLIES 4
Alfred.NESWADBA
in the bottom status-line of the application you have an icon (looking like a toothed wheel) and there you can choose the workspace you want to load, a workspace for Map-Classic should be included.
Other chance would be to start the command _WORKSPACE.
BTW: within the classic workspace you do NOT have all commands available in your Map3D!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Thanks for the reply.  I set the map classic workspace with no problem, but when I open cad it's back to the 2d drafting workspace.  I haven't had this problem in the past.  When I finish this current project I'll have to change my ways.Smiley Sad
Alfred.NESWADBA
Have a look into the start-icon-properties. You can give the name of the workspace as a startparameter for AutoCAD. Take a look >>>here<<< about the startparameters ("/W" is what you will look for).
- alfred -
Alfred NESWADBA
NateMoore
Alfred has the right idea.  http://gisexchange.typepad.com/blog/2011/05/map-2012-default-workspaces.html might help a little also.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
”Boost
