AutoCAD Map 3D General
Valued Contributor
rick-chappell
Message 11 of 21 (2,452 Views)
Re: Map 2012 Coordinate system files missing
05-06-2011 09:00 AM in reply to: dwolford
Excellent. Thanks for sharing!
New Member
dmtruji
Message 12 of 21 (2,440 Views)
05-07-2011 07:23 AM in reply to: rick-chappell
I have installed Civil 3D  2012 and I have the same problem with the coordinate system library. I have already created the new environment variable but the problem still persist. I must say that when I go to the system properties menu I can´t find any variable named MENTOR_DICTIONARY_PATH so I create one with that name and the value C:\Documents and Settings\All Users\Application Data\Autodesk\Geospatial Coordinate Systems. However I'm having the same problem and appreciate if you colud help me.
P.D. Sorry for my english
David Marin Trujillo
Active Contributor
andram
Message 13 of 21 (2,422 Views)
05-09-2011 05:10 AM in reply to: dmtruji
Hi David,
You will have to do a clean uninstall of all Autodesk products including Civil 3D, and clean out your registry of all Autodesk entries. See the solution to this thread written by Rick Chappell.
New Member
dmtruji
Message 14 of 21 (2,419 Views)
05-09-2011 06:28 AM in reply to: andram
Thanks andram. But what about if I want to maintain my old installations of Civil 3D 2010 and 2011?
David
Active Contributor
dwolford
Message 15 of 21 (2,413 Views)
05-09-2011 06:46 AM in reply to: dmtruji
The MENTOR_DICTIONARY_PATH (MDP) varible is created for the MapGuide Installation.  My Map3D 2012 tried to use the coordinate system files associated with Mapguide in the MDP path.  Since your conflict is with Civil 3D you may be having a somewhat different conflict, ie your problem isn't with the MDP path since it never existed on your system until you created it.  In the following directory "C:\Documents and Settings\All Users", I have 6 different folders with varied names regarding the Geospatial Coordinate Systems.  It sounds to me like the software you installed last (MAP3d guessing) is trying to use the existing Civil 3D coordinate system folder and thus it is unable to find the "Datums.CSD" file.  I am no expert though, so please take my suggestions with a grain of salt.
Active Contributor
andram
Message 16 of 21 (2,408 Views)
05-09-2011 07:04 AM in reply to: dmtruji
Unfortunately, you won't be able to reinstall 10 or 11 and have all three work properly. At least not that I've discovered.
rgladden
Message 17 of 21 (2,236 Views)
07-18-2011 09:29 AM in reply to: dmtruji
Well this worked for me. The issue here is a simple conflict of file folder names and newer code it appears. I cant believe all these people that have been installing and reinstalling over and over. That is just crazy to reinstall everything and uninstall everything just because a folder has a naming conflict. All you should have to do is go to the following location:
Most likely if you have multiple installations of civil 3d, you will see the folder Geospatial Coordinate Systems and then several others with the same name and Temp at the end or Temp2012. Civil 3d 2012 is looking for the folder that does not have the temp2012 at the end, despite having created that folder itelf. This is a simple bug and the programmers need to fix it.
You can take the existing folder named "Geospatial Coordinate Systems" and simply add the word OLD to the end of it. Now, I made a copy of the one that 2012 created (on my computer it was named Geospatial Coordinate System Temp2012). Then i reneamed the copy to what 2012 is looking for: "Geospatial Coordinate Systems". You probably dont need to make the copy but can simply delete the "Temp2012" part, but i retained it. Now it should work for you. I am not sure how that will affect your older versions of cad, but you can at least go in and rename the folders again if you need to use 2010 or 11. At least this way you dont go through the hassle of reinstalling everything and needing to uninstall your previous versions because of a simple folder name conflict that can be fixed in about 45 seconds.
rcouillard
Message 18 of 21 (2,030 Views)
09-28-2011 11:09 AM in reply to: rick-chappell
I tried what you suggested, but it did not work for me. I will keep trying though because I do not want to have  to reinstall all of my software. Anyone else find alternate solutions?
LeafRiders
Message 19 of 21 (1,794 Views)
12-28-2011 08:57 AM in reply to: rcouillard
Seriously this hasn't been fixed with SP1?
I have the same issue with Civil 3D 2012. Basically an expensive paper weight as we speak. I cannot define the coordinate system, the list that was available in 2011 and previous is not available. When I type anyting into the GUI there is an immediate Fatal Error.
I don't recall these things ever being an issue in past versions. I guess our IT department will send Autodesk the bill for 100s of computers they need to fix with 1-2 hours of IT work... Or i'll uninstall everything, cleanup all the registry files and proceed to reinstall 2011. Since my subassemblies also failed to install within Civil 3D 2012.
Active Member
parker
Message 20 of 21 (1,508 Views)
04-03-2012 09:45 AM in reply to: rgladden
Renaming the folder and restarting C3D did it for me..everything came right back..Thanks!!!
You are not logged in.
Ask the Community
