I am running Civil 3D 2011 32 bit. We are running 9.31 ArcSDE 32 bit. I am creating a connection using SQL SERVER Spatial Connection. I can see all of the database, but when we connect and it reads the Schema it is blank. Any Ideas?
I would use the "Add ArcSDE Connection" if that is what you are trying to connect to.
For Map to recognize a schema in SQL Spatial it would have to be setup in or with the Map Schema Format.
