AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
MEASUREINIT not working
4 REPLIES 4
367 Views, 4 Replies
Hi there,
I have a client with two work stations running AutoCAD Map 3D 2013 in Classic Map mode workspace. The system variable MEASUREINIT is set to <1>. However, when you begin a new drawing and type MEASUREMENT the variable is always <0>.
Has anyone else noticed this?
I only have the standard version of AutoCAD 2013 but it functions accordingly on my version.
Thank you in advance for your help.
Phillip
4 REPLIES 4
Murph_Map
Are they starting with an metric or imperial dwt?
Murph
Supporting the troops daily.
in reply to: Murph_Map
Thank you for your reply.
Sorry, I guess I didn't explain myself clearly enough. If they don't use a template but simply open AutoCAD in a new drawing from scratch, the global system variable MEASUREINIT should define the drawing mode (either Metric <1> or Imperial <0>)
In the standard AutoCAD 2013 this works fine. However, in Map 3D 2013 no matter how the MEASUREINIT variable is set, the MEASUREMENT variable remains at <0>.
Phillip
olivier.eckmann
in  AutoCAD 2013, default template is acadiso.dwt so MEASUREINTI is used.
in MAP 2013, default template is MAP2DISO.DWT so MEASUREINIT is not used
Olivier
in reply to: olivier.eckmann
I will investigate that. Thank you Olivier.
”Boost
