AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
MAP 3D EDIT THEMES
3 REPLIES 3
522 Views, 3 Replies
MAP 3D EDIT THEMES
Hi All
I have a series of polygons in my map (about 200 or so) which i have created a Theme for with a range of colours and labels. My question is once I have created the theme is there any way to edit it afterwards i.e. change the colour range or edit the labels without having to delete the theme and start it again. Am i missing something obvious?
Cheers
Paul
3 REPLIES 3
parkr4st
in StyleEditor select the theme in the thematic rules by clicking on the item you want to change the style of.  i.e. the third line down style column, fill block and change the attributes, apply and close.
dave
in reply to: parkr4st
Yes thank you park4st
parkr4st
In that case, return to Style Editor,  click on New Theme.  This reopens the current theme which you can modify.  When you click ok in the Theme Layer and return to the Style Editor you will have an extra thematic rule, usually the bottom one which you can delete as it doesn't refer to anything you want themed.
dave
”Boost
