Hi All
I have a series of polygons in my map (about 200 or so) which i have created a Theme for with a range of colours and labels. My question is once I have created the theme is there any way to edit it afterwards i.e. change the colour range or edit the labels without having to delete the theme and start it again. Am i missing something obvious?
Cheers
Paul
Solved by parkr4st. Go to Solution.
in StyleEditor select the theme in the thematic rules by clicking on the item you want to change the style of. i.e. the third line down style column, fill block and change the attributes, apply and close.
dave
Yes thank you park4st but this only changes the style of the individual element, this is not very practical when i want to change the pallette or edit the labels for all the elements (as mentioned above 200 or so).
Any ideas anone?
In that case, return to Style Editor, click on New Theme. This reopens the current theme which you can modify. When you click ok in the Theme Layer and return to the Style Editor you will have an extra thematic rule, usually the bottom one which you can delete as it doesn't refer to anything you want themed.
dave
